Number parameter without digits
TJunker
Hi everyone,
i want to "label" one of the parameters into my part. So far no problem using the text sketch tool and extrude feature. However, the text shows also all of its digits which means instead of "300" i get "300.000000", which makes it already impossible to get only one parameter labeled.
Is there a way to truncate the digits
  • create Integer parameter PLUS_TOLERANZ_ROH_INT
  • add relation PLUS_TOLERANZ_ROH_INT = plus_toleranz_roh
  • use PLUS_TOLERANZ_ROH_INT parameter in your "label"
MH
Martin Hanák
2 REPLIES 2
MH
Martin Hanák
you need to delete the existing parameter and create a new one of type "Integer".
no other way.
