OBJ of a simp rep of an assembly gets exported with incorrect coordinate system
SP_10744780
2-Explorer
Hello.
I am using Creo Parametric 9.0.5.0 to export a simp rep (an assembly) of an assembly to obj format. I activate the required simp rep, then go to File --> Save as, and then change the type to "Wavefront (*.obj)". Export Wavefront dialog box is then opened. With the simp rep active, I click on "All" under the "Groups to export" section and then select the coordinate system that I want as the origin of the generated obj. I then adjust the values under deviation control, and click on "OK". When I open the generated obj file in Creo itself, I see that the origin of the file is in another location, which is different from the one I selected.
Am I missing some step in the export process?
Thank you.
Hi @SP_10744780,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Thank you,
Catalina
PTC Community Moderator
PTC
I know this post is a little dated, but did anyone find the answer to this request? I'm having the exact same issue on my end. Thank you in advance!
