Is there any way to open a part from a bill of material table present in drawing???
everytime while updating a part drawing, we need to type a part name which is a drawing no. in my case. so iwant to open a part or its drawing from bill of material table present in drawing file.
Hello @kbhavsar-3
don´t know if it´s possible, but can provide you alternative solution.
It´s based on drawing format rearange. ADD DESIRED PARAMETER OUT OF DRAWING SHEET. Than you can edit parameter from drawing space (don´t have to open part - parameters).
See following picture:
At the end you can edit desired parameter directly in drawing space and it will not be pritnted on drawing.
Hello @mbonka,
Thanks for the suggestion. but i donw want to change the parameter. i want to open a drw file to update dimensions, etc. so if i can add anything in one more column which will open my drawing of that part.
If i will have 50 parts of assembly. i will have to open each part drawing file by typing its name. in place of that, i need something which is there in bom table of assembly drw file. which will open up my drawing file of any part.
Sorry l miisunderstand your question...
Really sorry but don´t know answer to your question ![]()
Its okay. no problem at all.
