Has anyone found a single improvement with the new exdloded view dialog box ! We just upgraded to Wildfire 4.0 from 2.0.
In wildfire 2.0 it was fairly easy to create exploded views & offset lines for exploded hardware and what not....
Basic steps VIEW / VIEW MANAGER / EXPLODE select the explode state you want to modify right click EDIT ...
move your components around .... Done .... create offset lines pop up window was right here also !!!!
Wildfire 4.0 lets see VIEW / VIEW MANAGER / EXPLODE select the explode state you want to modify right click NO modify isn't here.... lets guess where might they have put that now !!!! double click it NO ? click the EDIT button NO ? Hmm click the Properties tab, I'm getting warm I know it ! oh hover your mouse over all the icons in this window there it is EDIT POSITION ! thats it... This brings up the same exact window as wildfire 2.0 .....
Move your parts around works exectly the same ! Good job guys... waite it gets better ... think you done hold on don't click that close button or you'll loose all you changes, click the LIST button now right click and SAVE ! very intuitive....
Ok now lets create them offset lines .... Wildfire 2.0 that windowwas basically right here after you were done movingparts you clicked OK / SAVE. some small window was there click OFFSET LINES / CREATE ...
lets see where is that in Wildfire 4.0 .... Hmm Close the view manager "really close it" it's not in here anymore ... lets see where might they have moved it ? I want to create offset line related to the current explode state let see ..... lets look all over the place for about 20 minutes ... waite lets beat your head against the wall for a while that might help .... NOPE still can't find it. OK call tech support .....Oh all you haft to do is click VIEW along the top edge of the screen EXPLODE / OFFSET LINES / CREATE .... very intuitive....
Oh this open this same little window that was right there in Wildfire 2.0
Lets just say I thinkThis Improvement SUCK's
Oops I thought I was done but what the heck, I have a little bit more to add before I go home...
Tech support forget to mention to me that after you add the Offset Lines, you need to go back into the view manager window and Right click the current explode state that now has a + sign and click save !
just saving the part won't save the Offset Lines you just inserted... No you haft to open the View Manager Window and save the Explode State ! explicitly or you will loose your Offset Lines !
Very!Very intuitive !!!!!.... I love it ..... Thats all have a good weekend : )
Doug
That's a good analogy ! what I want to see from "PTC" is the enhancement request to change this dialog box, or a single complaint about how it functioned prior to them totally redoing it.
