I am using Creo Parametric - Release 3.0 (connected) 3.0 M140
Here are the errors that I faced
ERROR - D:\PTC\Creo 3.0\M140\Common Files\text\config.pro, linenum 114: Keyword 'CLR_PRINT_PLUS_MINUS' is not valid.
remove line containing CLR_PRINT_PLUS_MINUS option from D:\PTC\Creo 3.0\M140\Common Files\text\config.pro file. This resolves the problem.
