Organizing CREO parameter types
Inho-_-
Is there anywhere where the Creo parameter types are organized?
For example,
&Model_name : ???
&sheet_number/&total_sheets : ???
Like this...
3 REPLIES 3
tbraxton
(To:Inho-_-)
The parameter editor will display all parameters available in a file. Keep in mind that there are many different types of parameters in Creo and they are structured to data objects (sketch, feature, model etc.). Using the parameter editor, you should be able to filter all valid parameters for a Creo data object.
Tools tab-> Parameters
Involute Development, LLC
Consulting Engineers
please read https://www.ptc.com/en/support/article/CS133915 document.
Martin Hanák
Inho-_-
(To:MartinHanak)
Thank you!!!😁
This is exactly what I was looking for.
