Overwrite dimensions missing
DonSenchuk
We run our drawings (and models) through the publisher when they are checked into PDMLink. For drawings we're creating PDF files. One of the engineers just pointed out that the publisher is omitting the overwrite dimensions from his drawings upon publish.
When I open in Creo and save as to PDF, the dimensions show up properly.
When I use Custom Check In to create viewables (.PLT file), the dimesnions show up properly.
CS104165 is the closest the support pages come to this one and it's apparently not reproducible.
In looking at the recipe editor, I can see nothing that is specific to overwrite dimensions.
Has anyone run into this? And if so, how did you solve it?
Creo 2.0 / PMDLink 10.1
Are you sure they aren't there? Perhaps they are printing white.
