PDF Export
AV_5935998
PDF Export
I am using Creo Parametric - Release 3.0 (connected) 3.0 M100
When exporting a drw to pdf file, some of the lines appears thick on the pdf.
tbraxton
(To:AV_5935998)
In Acrobat (or Acrobat viewer) when viewing these drawings try the following key sequence:
ctrl+5
This should set the line weight for visible lines so they are properly presented for viewing.
Involute Development, LLC
Consulting Engineers
If you search a bit here you might find a past discussion about PDF line weights and the like. Perhaps the following result will prove useful:
Past PDF line output discussion
