PDF export file size
MB_10357724
For some reason, all my exported PDF file sizes are huge. May i know the ways to optimize the file size.
Here is the pen table details we are using.
! PROe DEFAULTS
! COLOR_NAME VISIBLE COLOR
! letter_color yellow
! highlite_color red
! drawing_color(geometry) white (pen1)
! background_color dark blue
! half_tone_color gray
! edge_highlite_color blue
! dimmed_color gray
! magenta magenta
! section_color cyan
!pen 1 Geometry, curves, volume
!pen 2 Letter
!pen 3 Hidden
!pen 4 Highlight
!pen 5 Sheetmetal
!pen 6 Section
!pen 7 Dimmed Menu
!pen 8 Edge High
! current settings for Pro/E drawings
pen 1 color 0.0 0.0 0.0; thickness 0.007 cm
pen 2 color 0.0 0.0 0.0; thickness 0.007 cm
pen 3 color 0.0 0.0 0.0; thickness 0.010 cm
pen 4 thickness 0.10 cm;color 0 0 0;SYSTEM_SELECTED_COLOR
pen 5 color 0.0 0.0 0.0; thickness 0.010 cm
pen 6 color 0.0 0.0 0.0; thickness 0.010 cm
pen 7 color 0.0 1.0 0.0; thickness 0.007 cm
pen 8 color 0.0 0.0 0.0; thickness 0.030 cm
please provide exact steps you use to get PDF file.
Your pentable is not the source of the problem.
Upload some test files.
Martin Hanák
Check this settings
@MB_10357724 wrote:
Check this settings
Stroke all fonts option affects PDF size, if a drawing contains a lot of texts displayed using TTF font.
Martin Hanák
aputman
(To:MB_10357724)
I use CutePDF printer rather than Save As PDF.  Using Print, you have the option to do a Complex overlap check.  This greatly reduces the file size for me.  If there is a solution to do this same overlap check using Save As, I would certainly consider using it myself.  I have tried so many different options and nothing else works this well.
StephenW
(To:aputman)
There is a time punishment for using complex overlap check. On a large drawing, it can take minutes to create the PDF.
