PDF export to network location doesn't wok
glászló
Hi!
Currently we are storing our design related files (XML, PDF, Sheets ...) in a shared network location. Everything is exported fine to the network location except PDF files (this means Schematics has the write permission to the location). PDF files are exported but become a 0byte file which can't be opened. So I have to export PDF-s to a local location than copy-past it to the shared network folder, it's really annoying actually.
Is this a known problem? Is there some solution for this?
Thanks!
Laszlo
0 REPLIES 0
