Parameters & formats
John.Pryal
Hi all,
i am desperately searching for a way of passing information created in layout to a drawing format. Is it possible to create a parameter in layout mode, & have that same parameter appear in a drawing format. What i am trying to achieve is to have a central location for all parameters ie.a layout, & to just have to enter a value once, whether it be a number or a string, & to have all components & drawings (formats) see these parameters & update accordingly. I know about declaring layouts, but how do you declare a drawing format to a layout, can you even do that?
Thank you in advance
John
It is not possible to directly declare a layout to a drawing. You have to declare a model to the layout. By doing so, the layout parameters become global model parameters of that model. These global parameters can not directly be used in drawings. In a drawing you can only refer to local (model)parameters.
I allway create local parameters by adding relations to the model.
e.g.: model_parameter_drw = model_parameter
When I see the extension "_drw" in the reference on the format, I know it is driven by a layoutparameter.
