Paramter with range value
mbalasubramaniy
2-Explorer
Can any one tell me how create a parameter with a range of value likely (100-200) without restricted parameter...Because i the parameter range differs for various case.....I am working in Creo/Notebook for driving a part with design inputs......
4 REPLIES 4
Maybe you can do this by adding a relation to control the value of the parameter.
Example :
if parameter<100
parameter =100
endif
if parameter>200
parameter=200
endif
Hope this helps.
Or evalgraph()
how come evalgraph can be used to control the range of parameter????
i don't understand the possiblity, can you explain it for me??????
It depends on how you wish to use the parameter. It is an evaluation tool for a 2D matrix.
