I have saved the CREo 2.0 file as parasolid(*X_T). Again i have opened the same in CREO. But it is not opening correctly. Some surfaces are missing & some surfaces are distorted. Why such problem is encoutred? Please guide.
Welcome to the forum, Anuradha.
Sometimes this happens depending on the complexity of the geometry.
It is good you test the export. There might be some options in the export settings that will help.
You can also try a STEP export to see if it happens in other formats.
These are the available export options for parasolid. They can be set in config.pro, or in the options dialog during export. Please note that this file may be created in your working folder and can affect future exports.
http://communities.ptc.com/thread/55571?tstart=0
Or Neutral file.
Or if you are stuck with what you have, you have to try to fix it with IDD and surfacing tools.
