Part - Copy Geometry - Bodies - Hide Copy Geom Feature
jchance
11-Garnet
i have a part where i am using copy geometry(external).  I put in the assembly i want to reference, deselect Publish Geometry, and then choose Bodies and select the body i want to reference.
I want to hide the body when i'm all done.  Creo is not hiding the body.  I have created a new layer and hidden the layer but that isn't working either.
See screenshot attached.  The Tubing should be the only piece that is visible.
Creo 8.0.10.0
kdirth
(To:jchance)
When adding the copied body to the layer, change the selection filter to body and select it in the window.
kdirth
(To:jchance)
jchance
11-Garnet
(To:kdirth)
This 100% worked.  Not very intuitive!
Thanks so much!
