Part and Assembely model Parameter to comes in part drawing & assembely drawing
ms-8
Some parameters in part model ,that same parameters to comes on part drawing parameters.
mbonka
(To:ms-8)
Hello muthukumar s
princip for parts and assemblies is the same. The key mark is "&". See attached picture.
If you want call parameter from part or assembly write it in following shape:
&parameter_name
Hope it can helps
Regards
Milan
8 REPLIES 8
mbonka
(To:ms-8)
Hello muthukumar s
&parameter_name
Hope it can helps
Regards
Milan
llokesh
7-Bedrock
(To:ms-8)
Use  &model_name
this will enable you to grab the Model part/ assembly number in the drawing!
ms-8
(To:ms-8)
Hi Milan bonka
Thanks for reply ,This I know ,But I want , what are the parameters in the part model that same parameters comes in {Drawing(Main Ribbon >tools > Parameters>it will come (thats I want)}
This window for parameters in part model
this window for parameters in part drawing.
This is I want. Please reply .
llokesh
7-Bedrock
(To:ms-8)
To answer your Question.
delete the parameter (PART_NUMBER, DESCRIPTION, REFERENCE NUMBER) from Drawing parameter dialog box only.
go to the drawing and replace the template (.frm)
This will pick Parameter (PART_NUMBER, DESCRIPTION, REFERENCE NUMBER) from the Part.
I hope this helps!
mbonka
(To:llokesh)
Think lokesh Hk is correct...
ms-8
(To:ms-8)
Hi lokesh
It's not working.
I want part model ,parameters (dialog box having some parameters in string method ) , That parameters to comes on above part Drawing window (parameters dialog box )
Mahesh_Sharma
22-Sapphire I
(To:ms-8)
Muthukumar,
Check reply from Matthew in earlier post Relating drawing parameters... Is it possible?
I think that will help you.
llokesh
7-Bedrock
(To:ms-8)
Hi Muthu Kumar,
To understand your question.- You wanted the parameter list in "part Parameter tab" to be copied in the "Drawing parameter tab" as well.
You can do it in two methods:
You can copy(CTRL+C) and  paste(CTRL+V)  the User defined parameter from "Part parameter tab" to the "Drawing Tab"
(The above method is applicable if the value is different from the part parameter and the drawing parameter tab, example the Image you attached has Parameter value for
"Part_number"  for drawing and part parameter tab is different )
If the Value are same for parameter (ex: description(from your image attached)), you may need to write a program in drawing which comes under TOOLS- DRAWING PROGRAM as suggested by Mr.Mahesh Sharma
If you want to know how the drawing relation are written
Relations in Drawing Program
Hope this is helpful!
