I have a harness that contains 23 wires. The harness is approximately 6m long. It is initially bundled in two bundles, coming from two connectors, after about 1m it must transition to a "flat" bundle where they are routed together. This should follow a specific curve and at one point be coiled 4 turns before continuing flat. It then transitions to 23 tabs/connectors.
Round bundling between two Locations is ok, but is it possible to have a flat bundle or route? I guess that the first wire can be routed along locations on my predefined curve, but how to I ensure that the remaining 22 wires follow the "flat" path that I want?
