Community Tip - You can subscribe to a forum, label or individual post and receive email notifications when someone posts a new topic or reply. Learn more!
X
How can I change the decimal places or significant digits in a pattern table? The table was created using a ProTable file with 8 digits. The pattern table shows with 3 only. I tried options, environment, etc. with no luck. Thanks[/i][/b]
Thank you. When I edit pattern table, I still get the 3 digits. But, if I edit on screen, I get the 10 digits that I set in config.pro. So, I can make that work. Thanks, again.
I am trying to do the same thing. Mine is placing parts in a pattern in an assembly. So I do not see where to set the dimension tolerance like you mentioned. Any help? See my screen capture attached.
