When you pattern a UDA the UDA does not update its references with the instance information in the pattern. Does anyone have any good work arounds to this?
I am making a isogrid similar to this challenge:
https://community.ptc.com/t5/3D-Part-Assembly-Design/Creo-Parametric-Community-Challenge-2-Isogrid-on-a-Curved/td-p/902365
The surface is a freeform surface and I have a UDA that measures from the freeform surface to the core pocket to determine the minimum thickness along the pocket edge and then creates a flat bottom extrude based off that minimum thickness point.
Hi @Chris3
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
