Pick many (Import Feature > Edit Definition)
rcrisp
Proe Users,
I have been using SolidWorks extensively for the past 3-4 years and now
thankfully I am switching back to Proe for a project and cannot remember
how to "Pick many" from Import Feature > Edit Definition menu. I have
orthographic DXF import views and I need to pick many entities, delete some,
and move groups of others around, to center them w/ the CYS. I remember
having a mapkey or something in Wildfire 2 and would utilize this feature
all the time, but in Wildfire 4, I can't seem to find any such way to
achieve this. Can someone help point me to a solution?
Thank you
Ryan Crisp | Senior Mechanical Engineer
Priority Designs
501 Morrison Rd.
Columbus, OH 43230
(614) 337-9979
<">http://www.prioritydesigns.com> www.prioritydesigns.com
CONFIDENTIALITY NOTICE: This email along with any attachments contains
proprietary information, some of which may be legally privileged. If you are
not an intended recipient of this email, you must not disclose, copy or take
any action in reliance of this transmission. If you received this email in
error, please contact the sender and permanently delete all copies of the
email and any attachments.
Ryan,
After entering Edit Definition pick Edit, Select, Filter Options -
that's where you'll find Pick Many
Mike
Didn't see the Wildfire 4 part. Now you're using Import Data Doctor.
In Import Data Doctor look at the Import Model Tree - you should see
Components, and if you expand the list you should see your surfaces.
Selection is standard Pro/E (Ctrl Key, LMB) - you can then delete or
perform other functions
If you don't see "Component" in the IDD model tree, you can just use
your Ctrl Key / LMB and pick surfaces, etc... like you do in core Pro/E
