Pipe Bend Tables
ptc-458350
Pipe Bend Tables
Hello all, need a little help. I'm working with Pro/Piping and can't remember how to create a bend table on the drawing of the pipe. I know that I need to use the bend_loc.dat file to create this but I can not find any documentation on how to do this.
I've created the bend_loc.dat file using the info dialog box but when I try to use the parameter's that I found in the help center in a repeat region it doesn't work.
I've been using Pro/Piping for about a year at my former employer but they had the bend tables all set up so I've never created one from scratch.
Any help or tutorials would be appreciated
3 REPLIES 3
Here are the directions, as well as a couple of tables.
Hope this helps,
Arnold
Hey Arnold,
Thats great.
Can you please share the values which you have assigned to Creo Bend machine table??
Repeat region values
It's been 8 years.
