Planar Constraint
DenisJaunin
Planar Constraint
Hello
To define a binding plan support on a surface, binding plan support always gives the same z-axis.
Can you change or it is done on purpose.
Kind regards.
Denis.
Hello
Nobody has an explanation on this plane stress always forcing the Z axis?
Kind regards.
Denis
StephenW
(To:DenisJaunin)
You may have better luck getting an answer by moving this to Analysis and Simulation group.
Ryan Kelley‌ can move this post to that group
Thanks for notifying me, Stephen. I've moved this discussion into the Analysis and Simulation‌ sub-community as you suggested.
What is this "binding plan support" you speak of?
