Is there a way to port over Creo Options over to Creo+ Options for all the setting?
Dale,
Try the PTC_CREO_ALT_SETTINGS_PATH in your Creo+ config.pro to point to your onsite Creo config.pro file (or a copy).
What if they are two physically different systems?
Copy the onsite config.pro/config.sup to your Creo+ computer in any folder, then use the setting for the alternate locations.
Friday I had copied the config.pro (we do not have a config.sup) to the other computer, but colors were not the same. I am guessing that mapkeys will need to be updated for Creo+ but I have been able to go through them all yet.
One mapkey was to change to a special color for a special print and then another to change back these didn't work, so I wasn't sure if I was missing something in the Creo+ Options versus Creo Options.
just one note...
I guess Creo+ is now Creo 11.0.
In Creo 11.0 mapkeys are saved in separate file, not in config.pro.
See https://www.ptc.com/en/support/article/CS416002
Actually, Creo+ is the cloud based licensing version of the Creo.
I am sure Martin is fully aware of that. What Martin is referring to is the new Creo 11.0 mapkeys.pro functionality:
https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/whats_new_pma/core_seperate_mapkeys.html#
Mapkeys are no longer contained in the config.pro
That's why my post below mentioned that "I will have to try that method when I get back to my other system".
Thanks!!
Thanks!!
I should have read farther on down!
I will have to try that method when I get back to my other system.
