Hi, quick question from sheet metal newbie:
Is it possible to add the bend radius to the sheet metal bend note, if so how? And is it possible to automate the process?
regards, audun
Hi Audun,
starting from Creo 3, it will be possible to add &inner_radius and &outer_radius to the smt_bend_notes_order config to add the actual inner & outer bend radius of the bend.
Hello
I have just posted exact same question here, but not answered yet. Wondering if you have found solution?
Regards
Andy
Audun,
You may try config option smt_bend_notes_order with value as &type&direction&angle R&SMT_DFLT_BEND_RADIUS
"R" is to show radius for &SMT_DFLT_BEND_RADIUS
Hi Audun,
