Jul 2, 2015 1:57 PM UTC
Pre Set parts so they dont show on BOM when generated.
Hi Guys,
is there a way you can set part during modelling or when assembling so it doesn't show on BOM when generated in drawing? I mean I have plenty of parts which are not good in BOM and I have to filter them out one by one. For example air cylinder is made of mounting bracket, main body and slider. On BOM I only need assembly name and bracket. I would like to be able to preselect parts which I don't want to appear on BOM before I generate BOM table.
Hopefully you can get what I am trying to explain here.
Thanks.
TomU
TomUAnswer
Jul 2, 2015 6:20 PM UTC
It is a repeat region filter, and I had the syntax wrong.  It should be &ASM.MBR.STOCKLIST != NO
Sample drawing and assembly with two drawings is attached. (Creo 3)  Open prt0002 and change the STOCKLIST parameter from 'NO' to 'YES' to see it reappear on the BOM.
TomU
Jul 2, 2015 3:24 PM UTC
One approach is to add a parameter to your models and then filter on that parameter in the BOM.  In the past we used a "STOCKLIST" (yes/no) parameter.  In the repeat region we had a filter that said &asm.mbr.STOCKLIST <> NO.  (This way you don't exclude things that are missing this parameter.)  If you add this to your start parts, you can even preset the value.  (Assemblies == NO and Parts == Yes)
rmuller10-MarbleAuthor
Jul 2, 2015 4:19 PM UTC
Tom, thank you for your help.
I am not sure of one thing. I can add YES/NO parameter to my start part. I have a BOM table which has Index, Part Number, Description, Qty and Vendor in it. Should I add this &asm.mbr.STOCKLIST <> NO as another column? Or is it filter rule I need to add? I tried and to add it exactly as written and it gives me some error.
Do you know off some other solutions to this? I like the parameter way anyway.
TomU
TomU23-Emerald IVAnswer
