Printing .PDF files
kmcbrine
Printing .PDF files
When I create .PDF files in ProE, the resulting print has very poor line quality. Does anyone know how to create more "crisp" images.
thanks
5 REPLIES 5
JohnGetty
(To:kmcbrine)
Are you using the PDF print button through the ProE GUI, or the print manager?
I tried it both ways.
We use the print to pdf button.
Under the tab FORMAT I choose, "stroke all fonts" and "grayscale".
Under the tab CONTENT I choose, "layers none" and "All parameters.
Hope you find what works,
Frank
davehaigh
(To:kmcbrine)
Could it be that your problem isn't in ProE but in the settings in Acrobat?
In preferences Page Display there is a pick named Enhance thin lines which if it's checked makes drawing lines thicker.
David Haigh
StephenW
(To:kmcbrine)
Also, you might want to use "monochrome" instead of color or grayscale.
Check if you have lineweights set in your config.pro or if you have a pen table file. If so, figure out which colors the offending lines are and adjust the thickness of the lines.
