Pro/E Wildfire 5.0 - Publish drawing into PDF
mselamat
Hi all,
Good day.
When I preview my drawing it display like this:
After I publish it into PDF file it become like this:
See the top dimension difference (16 +0/-0.15)
This is just one example, there is more of the same case like this.
Is it the PDF software issue or Pro/E?
I am using Adobe Acrobat Pro Extended version 1.6 (Acrobat 7.x)
Please help.
Muzzammil
1 REPLY 1
this can be WF5 bug.
Do you use PDF publish option available in WF5 -OR- do you use Windows PDF printer ? Test both variants.
MH
Martin Hanák
