Pro/Engineer Wire Harness Tutorial
in this tutorial i show you how to create a simple harness using points, curves and swept blend.
If you would like to follow i along i have provided the models in my dropbox for free download.
(Right click and save the step files)
Lesson Assembly:http://dl.dropbox.com/u/48619470/Cad%20Data/wire_harness_tutorial_asm.stp
The Complete wire harness assembly:http://dl.dropbox.com/u/48619470/Cad%20Data/wire_harness_tutorial_complete.stp
Hi Steve...
I appreciate the time and care it takes to generate a 30+ minute video. I commend your efforts to help further the community's knowledge and contribute to its success. Thanks for sharing your model and techniques.
I use some very simple basic modeling techniques to generate very similar results quickly from the Pro/CABLING module. Do you prefer modeling cables directly in Pro/E (or Creo) rather than using the cabling package?
Thanks again...
-Brian
Thanks for the positive feedback brian, i would much rather use Pro/Cabling, but that is an extra option that i dont have at home.
