Pro/PIPE pipeline colors
ptc-2048017
Hello, How would I go about making different colored pipelines in an assembly? It can't seem to find where it is that I would change the color. Thanks!
6 REPLIES 6
on the assembly, go on the top menu of pro/engineer: view / color and appearance; check a colour then components option and select the pipe(s - with ctrl key), done. Select another colour and the arrow button (select from model) to modify the colour for others components
Select View -color & appearance -assignment, select components, select one o more items -choose color, -apply
That doesn't seem to work for Pipes created in Pro/PIPE. I'm able to select all other components but cannot select the pipes.
and how to open the pipe and change the model or surfaces color?
CBenner
(To:RonanMASSOT)
If you are using Spec Driven Piping, you can assign a pipe color to each new spec as it is added to the "piping_spec_dir" file. That way, any pipe or fittings added to a pipeline created in that spec will automatically be the right color.
Chris Benner
Autodesk ® Expert Elite
how can agree this parameter " "piping_spec_dir"" in spec driving piping ? I don't understand. I need change color piping. 😕
