Pro/Program: Executing instances
GavinBRumble
Good morning Pro's (I just can't say Creo's yet),
We have been trying to EXECUTE a parameter value to an instance in a Family
Table with no success. Our goal is to drive different values into this
parameter in various Instances. It is understood that F.T. columns are the
only way for Instances of the Generic to have different values for a given
parameter. We were hoping that the EXECUTE>INPUT combination would
overwrite the *'s for the specific Instances we are EXECUTE-ing similar to
the way that a Relation will. However, adding the parameter in question to
a column in the F.T. causes Pro/E to ignore the Input statement altogether.
Are we trying to do something that just can't be done?
Thanks in advance,
Gavin B. Rumble, PE
Solid Engineering
336-224-2312
0 REPLIES 0
