ProFileOpen and the mnu-file
LarsZiegler
8-Gravel
Hello!
I want to open a *.gph file with the ProFileOpen dialog.
It works fine, but is it possible to use the defined "mnu" file in the directory
so thatI got the same dialog like "Insert" "User-Defined Feature..."
Thanks!
Lars
ProPath TheFile;
ProPath DefaultPath = L";
/* No default dirs */
ProPath *path_arr = NULL;
ProName *path_lab_arr = NULL;
err = ProArrayAlloc(0, sizeof(ProPath), 1, (ProArray*)&path_arr);
err = ProArrayAlloc(0, sizeof(ProPath), 1, (ProArray*)&path_lab_arr);
ProName Option = L"pro_group_dir";
ProPath *wValues = NULL;
int nValues;
err = ProConfigoptArrayGet(Option, &wValues);
err = ProArraySizeGet(wValues, &nValues);
if (nValues > 0)
ProWstringCopy(wValues[0], DefaultPath, PRO_VALUE_UNUSED);
err = ProFileOpen(L"Open", L"*.gph", path_arr, path_lab_arr,
DefaultPath, NULL, TheFile);
0 REPLIES 0
