I need the two points to coincide simultaneously so as to change the scale from 14.30 to some other number... i cant change the scale manually by trial-error method and zoom it to see whether it's coinciding or not
... i'm able to coincide any one pair but not both!! Using coincide constrain gives me conflits ![]()
Just drop the symbol sketch anywhere and then constrain it.
Just hit the check mark and it is now simply a sketch where you can change whatever you want.
