Problem of dimensioning in drawing and after printing the drawing???
ptc-5005856
hello everybody,
i have installed CREO-2 on my pc. but getting problem in drawing mode.
1)When i editing the dimensions given on the drawing the font size & font style chnaging everytime so i have to go back for editing and then come to original font.
2) While printing the drawing the dimensional orientation changes means tolerances given to the dimensions it get overlaped to orginal dimension and in case of angle
angle symbol over the dimension is so away from the dimension. again i have to go for editing this and aligning with different condition.
3)many times license not detected and again and again i have to configure the software with license file.
So how to stop these problems? plz revet.....
There are many settings that relate to dimensions, one of which is the PDF printing with true type fonts. If tolerances and dimensions overlap, this means they are not part of the dimension. When used properly, this should not happened.
License issues can be many fold. Contact your VAR or customer support to get this sorted out. They know what to look for. There are many posts that describe similar situations.
Please feel free to include examples in your post so we can address them individually. If you share the file, we might be able to help in more detail.
If you are "printing" via a generated PDF, then you neexd to set the setting "Stroke All Fonts" when generating the PDF.
