Can anyone guide to the options available in Repeat Region?
I want BOM where all the PARTS should be in BOM and not a single Assembly.
Also want all components of the sub-assemblies of top-level assembly.
I know the option of "recursive" and "filter"
But i want that Table.tbl file to be saved for future uses.
Right now when i am saving the table file after applying all settings like recursive and filter by rule "&asm.mbr.type==PART*
Next time when i use that table file. It only shows the PARTS of Top level assembly. And all sub-assemblies along with it parts get filtered out.
So every time i have to work with BOM for the same.
And everytime to identify the PART/ASSEMBLY i have to again add 1 column of &asm.mbr.type (Unwanted) and then i start to set default all settings to BOM and again have to apply the settings.
Can anybody help here?
I can't see any problem ... see attached files created in CR2 M070.
bulk items are not displayed because of filter defined in the table ... see below
&rpt.level > 1
&asm.mbr.type == PART
You have to investigate, how to display bulk items ... please do it by yourself 🙂
