Hello everyone, it's the first tutorial with Creo Parametric 5, for the exact I'm following this :
https://www.youtube.com/watch?v=8MrhiuYEoIQ
I can successfully do only the first pattert with reference to the axis and using the original non-mirrored rib feature
I always failed the pattern of mirrored speck, and n the wireframe preview that shows me when I failed, the last element of the pattern mysteriously it is not displayed ( it should be 7 and not 6. in pattern setting I put elements 7 and angle 360/7)
Thanks so much
It is due to accuracy, changed the relative accuracy to 0.0001 and got correct results. (File > Prepare > Model Properties > Change Accuracy)
I am attaching the ptc file with the failed pattern
thank you
Note: Part is created in Creo Parametric 5.0.1.0
exactly, the problem was just that. Thank you so much for your time
