Problem with importation part by solidworks
sportivo_cae
Dear all,
I have a problem with import a part in creo parametric 2.0
I created a part in solidworks, but when i try to opet this part in creo (on different format: .igs, .stp, .x_t ), i have an part not rfinement very well.
the figure in section show the problem
the sinusoid surface are not smooth.
any help please????
i import by solidworks file .204step
StephenW
(To:sportivo_cae)
Go to FILE - OPTIONS - ENTITY DISPLAY, adjust the EDGE DISPLAY QUALITY to VERY HIGH
Then go to MODEL DISPLAY, adjust the SHADE QUALITY to a value higher.
When you hit ok, you will need to save the settings.
It's also possible that your model was exported as faceted. You may need to look at the export options.
