Problem with parameters
FredrikIversen
2-Explorer
My problem is that two extra parameters adds in the model and I can´t delete them because the source is Intralink. I need to delete them because the parameter adds an extra row in my drawing title block. Anyone who know how I delete parameters whic is controlled by Intralink? The parameters which adds to the model is following: PROI_LOCATION PROI_RELEASE I already have the parameters so it would be duplicates.
You cannot remove the Ilink parameters, they are treated like system parameters. You should be able to change the drawing callout such that it will use these Ilink parameters. That should remove the extra lines. The only other way to remove these parameters is to take the files out of Intralink (stand alone) and remove them from the parameters list. They will come back if you decide to put them in Ilink again.
But why have they showed up? They wasn´t there from the beginning and they are only in this part.
Is there anyone who knows how to solve the problem?
