Problems with Keep & Repeat
cpalmer1
7-Bedrock
I'm having a bit of trouble upgrading from 18.1 to 19.0 v3 while keeping my customization.The only problems I'm having are the functions FUI_MOD_KEEP and FUI_MOD_REPEAT. I have both applications running off of the same  meDir/customize.m, meDir/StartUp.m, meDir/fluientui/layout.xml and customization folder. but for some reason the check boxes don't work the same.
===Example===
Keep + move_2pts
===Version 18.1 Trace ===
FUI_MOD_KEEP
MODIFY Wui_keep_repeat 'MOVE TWO_PTS'
INQ_ENV 10
LET Pelook ( INQ 6 ) 4
IF ( Pelook 4 = 4 ) 1
LET Chekeep ( FUI_MODIFY_KEEP ) 1
LET Cherepeat ( FUI_MODIFY_REPEAT ) 0
ELSE Assistance
LET Dummy 0
IF ( UA_GET_COPILOT ) 1 ASSIST
END_IF
IF ( ( Chekeep 1 ) AND ( Cherepeat 0 ) ) 0 ( ( Chekeep 1 ) AND ( NOT
  Cherepeat 0 ) ) 1 COPY
ELSE_IF
EXECUTE_STRING Action_string 'MOVE TWO_PTS' MOVE TWO_PTS
===Version 19.0 Trace===
FUI_MOD_KEEP
TRAP_ERROR
INQ_TOOLBAR_ITEM 'che_ModKeep'  { display error occurred Toolbar Item 'che_ModKeep' doesn't exist }
LET Chekeep ( ( NOT CHECK_ERROR ) AND ( ( INQ 15 ) = 1 ) ) 0
TRAP_ERROR
INQ_TOOLBAR_ITEM 'che_Repeat'  { display error occurred Toolbar Item 'che_Repeat' doesn't exist }
LET Cherepeat ( ( NOT CHECK_ERROR ) AND ( ( INQ 15 ) = 1 ) ) 0 Assistance
LET Dummy 0
END_IF
IF ( ( Chekeep 0 ) AND ( Cherepeat 0 ) ) 0 ( ( Chekeep 0 ) AND ( NOT
  Cherepeat 0 ) ) 0 ( ( NOT Chekeep 0 ) AND ( Cherepeat 0 ) ) 0 ( ( NOT
  Chekeep 0 ) AND ( NOT Cherepeat 0 ) ) 1 DEL_OLD
END_IF
Any Ideas how to correct this?
MaxR.Kublin
(To:cpalmer1)
Posting TRACE files qualifies you as expert user.
I don't have a OOTB answer, but some hints how to proceed:
- SAVE_MACRO ALL DEL_OLD "all_mac.txt"
-.do this in V18.1 and V19
- Use Tools of your choice to find the differences of the Macro "sets"
- or edit "all_mac.txt" with a Editor program of your choice
Hope this helps.
Rgds, Max
well, after comparing the two versions of the keep command I made a FUI_MOD_KEEP2 version, as follows.
DEFINE FUI_MOD_KEEP2
  IF (FUI_MOD_KEEP_STATUS = 0)
    TOOLBAR_ITEM OVER_WRITE 'che_ModKeep'  SET_VALUE 1 CONFIRM END
    LET FUI_MOD_KEEP_STATUS 1
  ELSE_IF (FUI_MOD_KEEP_STATUS = 1)
    TOOLBAR_ITEM OVER_WRITE 'che_ModKeep'  SET_VALUE 0 CONFIRM END
    LET FUI_MOD_KEEP_STATUS 0
  END_IF
  FUI_MOD_KEEP
END_DEFINE
It seems to do the job okay, but we'll see.
