We currently have ProductView Lite configured to publish on check-in. However, when we check in an assembly, it is gathering all components and library parts and publishing those as well - even if they have not been modified/checked in. The result becomes a very backed-up publishing queue.
Is there a way to only publish the intended items that are checked in?
Thanks!
Chrystal Harvey
Red Dot Corporation
