I have encountered some problem in proe AXX extension, the features cant obtained even it was already configured in ptcsetup.
Please see attached file for your references.
Check the version of AAX license in license. This may happen if license version of AAX is not compatible with current version.
You can check this in license file under Summary table, release column.
Hi Mahesh
Thank you for the reply
Here is the sample license file
FeatureName Qty Product Release Type Expiration Contract
#127 4 Mechanism Design WF 4.0 PreProd Ext perm 4A1109410
#210 4 Pro/ENGINEER Design Collaboration Extens WF 4.0 PreProd Ext perm 4A1109410
#PROBUNDLE_10119 4 Pro/ENGINEER Advanced Assembly Extension WF 4.0 PreProd Ext perm 4A1109410
#127 4 Mechanism Design Wildfire 5.0 Ext perm 4A1109410
# 4 Windchill ProjectLink - Heavy User Licen 9.0 Flt Opt perm 4A1109410
#PROE_FoundationAdv 4 Pro/ENGINEER Foundation XE (formerly Fou WF 4.0 PreProd Flt Lic perm 4A1109410
#PROE_FoundationAdv 4 Pro/ENGINEER Foundation XE (formerly Fou Wildfire 5.0 Flt Lic perm 4A1109410
#PROE_FoundationAdvAAX 4 Pro/ENGINEER Foundation XE (formerly Fou Wildfire 5.0 Flt Lic perm 4A1109410
They use wildfire 5.0 M060
Hello Renz,
License for AAX is compatible up to pre-production release of Wildfire 4.0. It will not work with any of the version starting from Pro/ENGINEER Wildfire 4.0 F000. It could be due to maintenance. You may check with PTC License Management.
PROE_FoundationAdvAAX license probably contains AAX. Configure Creo to run this license.
Martin Hanak
Hi Renz,
You may mark appropriate reply to post as correct answer, if that help you.
