Proe and PLMXML JT visualization integration??
ptc-3069690
I work in engine integration projects. so while routing tubings and pipes I have to copy the surfaces to the model, with which the tubes may foul, to get idea about real time clearances with them..I also use Siemens PLM for change management, which has the option of JT visualization.. so it will be very simple for me if i can somehow get this visualization while creating these tubings in PROE.. So please let me knw if there is any option for this.. Thanks..
If you are using the ProE to Teamcenter Integration, you will need the Siemens ProE JT Translator. It can be configured to save a JT to Teamcenter when the ProE model is saved to Teamcenter. The PTC JT translator license that debuted with WF4 is not compatible with the Siemens ProE to Teamcenter integration.
