Profile Milling Issues
SteveLucas
I am having a problem with profile milling. when I cut a diameter with a profile sequence I get a series of linear moves that leaves the diameter with facets all aroud it from the xy cuts instead of arc cuts. If I cut the same diameter with a window(follow hardwalls profile only), it cuts the diameter with arcs the way it should. I have my parameters set the samein both sequences (arcs only)but it seemsthe profile milling is not working the way it should.
Is this a software bug or is there a parameter or something I am missing? My postprocessors have not changed.It started afew of months ago after switching toWF5.I use profile milling a lot and this is really starting to bother me because now all my round parts need to be ground finished as a second operation. I know I can just use a window but profile milling is a lot cleaner when I can just select the model for mill geometery.
I am on WF5 M020X64
Sample of profile milling
M01
N1T8
M06
T8
S950M03
G0G90X.4861Y-.4861M08
G43Z.1H8
G1Z-.775F6.
X.4834Y-.4889
X.4664Y-.5051
X.4489Y-.5207
N2X.4309Y-.5357
X.4124Y-.5501
X.3934Y-.5638
X.374Y-.5769
X.3541Y-.5893
X.3338Y-.601
X.3131Y-.612
sample of window follow hardwalls profile only
M01
N1T8
M06
T8
S950M03
G0G90X-.4861Y.4861M08
G43Z.1H8
G1Z-.775F10.
G2X-.4861Y.4861I.4861J-.4861F6.
G1Z.1F25.
M09
N2M05
What about your accuracy settings?
Are you working with absolute accuracy?
Does the accuracies of the MFG, workpiece and reference part matches?
Daniel
