I'm working on a part out of a text book right now, (Drawing attached). It is simply two surfaces connected on a 60 degree angle. I'm trying to add a rib profile from one surface to the other. I draw a simple line sketch and then the rib option tells me I can't intersect the part or various other cryptic error messages. I watched a couple of tutorials on it, and it seems pretty straightforward.
I guess my problem is in the open ended sketch. Any insights. greatly appreciated.
Thanks.
hopefully it will
Ps:do not do it or just had another rib profile sketch and extrude Apply if you can not
I'm guessing here, but shouldn't the intersecting faces be part of a solid body?
Creo wants me to reboot to get my license back. I'll give it a shot.
yep, works fine with solids:
