Projected sketch protrusion
dgschaefer
You need to use the offset tool instead, no projection required.
Select the surface -> Edit -> Offset -> Select the 'expand' option
(upper left of the image below) -> Options Tab -> Sketched Region
Doug Schaefer
LinkedIn
0 REPLIES 0
