Projection Arrows in drw
rfarrell
Good morning,
Is it possible for projection arrows in a drw to "show" exactly the way they are sketched in the prt? For instance if the sketched xsection takes some 90deg turns?
Thanks so much.
StephenW
(To:rfarrell)
If you are showing the arrows from the section tab of the view properties, it should show the offset x-sections arrows as you have sketched them.
8 REPLIES 8
Welcome to the forum, Roger.
As far as I can tell, the only way to see how a section or sketch was created is to edit definition and set the view to the workplane. Alternatively, you could get in the habit of selecting the horizontal references so the orientation remains consistent.
Thanks for the welcome, really appreciate this community
Thanks for the help too. I have no problem showing the sketched xsec in the prt file, or in the drw for that matter, it's just that in the drw, the Projection arrows do not follow the sketch?
I missed the "dwg" part. The projection is always per the 1st or 3rd view projection rules (3rd by default) but you can fool the system once the view is placed by dragging it to the other side of the master view. I do not typically use the arrows other than section arrows. But I do often rotate a view for clarity, and state such in the detail view.
Maybe an example image of the what you are trying to do will help with understanding the issue. What is throwing me is the term "sketch".
Thanks again,
Here's a picture of the xsec.
StephenW
(To:rfarrell)
Excellent. Worked perfect. Thanks!
Thanks Stephen; I was getting lost in terminology.
That field does hide itself by default.
Glad you got it worked out, Roger.
Have a great day!
Thanks Guys! Really grateful for the help
