Pulling thread parameters in relations
ptc-1850564
1-Newbie
I want to extract the thread parameters of a tapped hole- like "PITCH", "THREADS_PER_INCH" ETC, equate a parameter to them and in turn use this in a relation. Is this possible-and if so,how?
2 REPLIES 2
Right click the hole in your model tree and select Info->Feature. Notice the "INTERNAL FEATURE ID" Under The Local Parameters section you see a list of the hole parameters. Add the following relations in your part: '--------- myparam=PITCH:FID_28270 '--------- ' PITCH is the parameter and in this case 28270 is the ID of the Hole Hugo
Thank you.
