"Eric Mills" wrote:
You can setup a watermark in the PDF as it is created.
"Peter J. G." wrote:
Hello, One way of doing it could be: Create a sketch and use Text. Export as Iges. Open a format - import the sketch - group it. change font and line style. Put in into a layer. Now you can turn on/off the layer. Good Luck 🙂
