Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Question about part relations
GrahameWard
I have a relation "d1=d0" between 2 features. If I change d1 from 0.1 to -0.1 and regenerate the dependent feature stays the same: i.e. it stays at 0.1. If I click on the feature >Edit, the dimension I changed to -0.1 shows up as 0.1, but if I go into the feature with Edit Definition it still shows as -0.1. I think this must be behind the problem as the relation is at the part level, between two features. How can I stop this from happening?
9 REPLIES 9
I've just dug up an old email from the PTC/User exploder list... Try $d1 = d0
Thanks, I'll try that. What does the "$" mean in this case?
From the Pro/ENGINEER Fundamentals Help Topics, the "$" character signifies an "absolute" value rather than a "relative" value. It forces the true signed value in the relation. Regards-
GrahameWard
(To:cfitzgerald-2)
But the absolute value of -0.1 is 0.1. I don't want that. I want d0 to change to a negative value if d1 is a negative value. Still, I will make a quick part to test this.
GrahameWard
(To:GrahameWard)
Yes, Grahame, you have analyzed it correctly; $ means preserve the signed value. It is often necessary in generalized relations. Watch out particularly for angular dimensions that need to swing either way from nominal zero.
Sorry for the confusion, I had the terms reversed, the "$" sign forces the "relative" value.
GrahameWard
(To:DELETEME)
