Question regarding my assembly and mechanism
ksengkit
I have a problem with my assembly and I wasn't too sure on how to make it work. For the assembly I would want the 2 struts to be able to move at the same time with a hole in the middle being the connector but i tried using pin connection but I'm still wasn't sure how to make it all fully assembled and stuff. Would anyone be able to take a look at my assembly and help me with it? Thanks!
2 REPLIES 2
gkoch
(To:ksengkit)
There is never a guarantee someone will actually look into it and provide a solution.
But from my experience you can increase the chance someone tries it, when you add the assembly (or better a simplified version, showing only the relevant parts) as an attachment (you can do this when switching to the Advanced Editor).
A picture of the situation may be another way to raise more interest.
Gunter
TomD.inPDX
(To:gkoch)
...or the discussion fell off the bottom of the page and didn't get noticed.
If you go to the advanced post editor, you can attach files.  It is best to save-as or backup as a zip file to make sure everything required is captured.
You can copy/paste images in the forum.  There is no longer the need to save the image and link it here.
