I have a model and on the front of it I created an offset quilt where all my graphics are displayed. It looks great but when I do a projection view & a cross section you can see the line for the quilt. Does anyone know how to remove the quilt from a specific view? I know I can hide the quilt in a layer but then it removes it from the entire drawing. Any suggestions?
Mike
Hello Mike
You can create a custom layer. In the drawing it is possible set different layer setings for every view.
In your case you can hide a specific layer in view where you do not need the quilt/surface.
Vladimir
Hello Mike
Vladimir
Hi Vladimir,
thanks for the help. I had never got that much in detail with layers. It is working the way I want now.
thanks
Mike
