REFERENCE VIEWER
lgejjagondanaha
REFERENCE VIEWER
How to check references of mirror features Parent/Child relation in reference viewer?
I am missing mirror reference, when I am checking parent (upright/immediate/direct) feature.
Please suggest,
Thanks in advance
Lokesha
don´t know answer about referance.
My advice is: Don´t use mirror featers in Creo.
Reason why not: It´s really bad function in Creo.
Example: Try to mirror some extrude feater, then try to change references in original extrude. Problem going to popup in sketcher.
Result: It´s is prohibitted to change reference in original feater, because it has a mirrored child.
Idea: Maybe it has something similar with your question about mirror feater reference viewer.
Hope it can help you...
Milan
KenFarley
(To:mbonka)
I agree that mirror feature is really annoying. Except if you are mirroring the full part. That works very nicely for me. The mirroring of individual features is horrible for the reason you suggest, and also because you can't redefine it to add another feature or remove one you selected previously.
